Just had a set of Carve 20" rims installed with 275/55 Michelin LTX M/S tires. They look great and the truck handles alot better but I have a few questions.
The dealer had 35psi in all four tires so I assume this is the factory recommended pressure but they did not change the sticker on the door jam to reflect this. The stock tires were 18" styled steel with 30psi/33psi F/R so why are my new tires inflated with the same pressure 35/35 front and rear?
I called the dealer to confim that 35/35 was the recommended pressure and they told me the recommended pressure was indicated on the tires but when I checked they only listed the MAX pressure.
Normally I run the factory recommended pressure but in this case I'm not sure what it is. I know some Tundra's come factory equipped with 20's so If you got one could you please check your door jam and post the info.
