Anyone know where I can find the PDF around here that tells you how to change all of the default settings using the "Multi Info Display"?? It has locking options, HVAC control options, and a bunch of other stuff you can modify from the default settings...
I just tried searching for 20 minutes with no luck (another reason to split into subforums)
Thanks in advance
Thanks in advance
