What all do I need to add 4wd to my 2wd tundra?
More than it's worth. Find a Tundra equipped with four wheel drive if that's what you really need.
  • Like
Reactions: Chappy R and Jimmbo
2005 Toyota Tundra 4x4 limited double cab 4.7l
Find a wrecked body 4x4. Unbolt your trucks body from your 2wd frame put on 4x4 frame... Seriously it is more expensive to convert than to sell and buy a 4x4 to start.
But here is a list of things needed from the top of my head.
Transfer case
Front diff
Computer
Switches
Trans axle
Rear output shaft
Front half shafts
Front wheel hubs
Some other suspension bits.
You might also need the 4wd transmission that goes to the 4wd transfer case and then to the front and rear differentials.
So yeah literally over 10k in parts.
Would be cheaper to find a 4x4 wrecked to pull needed parts but like I was saying at the top you would need almost the whole rolling frame minus engine.
