If you're like some people who find that your Toytec lift is sagging on the left side?
(Which is most likely caused by the Fact that your gas tank is on the left.
And because for the most part you are the only one in the truck 90% of the time. So most of the weight is always on the left.)
Any ways? Rather than buy a shim plate to level off your truck? What you could do is simply Swap the struts! Put the left side on the right and the right side on the left!!
At the very worst? Your left side will be a bit higher for a while. (Until it settles.)
Just a thought? It's worth considering!!
Good Luck!!
Good Luck!!
