Hi everyone, first post and needing help.
Some info. I own a 2000 Tundra access cab; I bought it a year old. It was owned by a Toyota salesman before me and had a Toyota Hitch and wiring harness when I bought it. I rarely tow, and at the end of last summer I went to tow a trailer and had no lights, checked connections, all good. Opened rear light cluster and found the converter, it has a single red wire and a large connector with the lights signals going in (part number PBT-GF30). I assumed the red wire is +12Vdc, I tested with a multi meter and no power. OK fuse is blown……….
I need to tow this weekend so I just spent 3 hours searching the forum, I have looked under the hood, removed drivers kick panel, looked under the rear seats, tested all fuses in the 2 fuse boxes and I cannot for the life of me find any fuse.
On the positive post of the battery I have 2 cables one to the Starter and one to the fuse box under the hood. I do not see where the O3 Option connector is.
I do not know or, how to find out if the truck came with the Towing package from new.
Has anyone come across this.
Any help or advice is greatly appreciated.
