Sorry fellas, if you've got an 05-06 Access Cab, they don't work. Well, they don't work unless you are willing to cut a little bit. I have those same ones on my truck, and I got them to fit, but I must admit, they are a little rigged. Since they were so cheap, I figured I would take it on as a little project for myself. I actually bought them brand new off Craigslist off a guy that bought them for his 2005 AC, but then realized they didn't fit so he sold them to me for 30 bucks. I figured if I was just able to cut the crap outta the inside of the clear corner itself to get them to fit, big deal. But I did however had to cut the small plastic retaining clip from the stock headlight. I did it very cleanly though with a dremel. I made sure though that the factory corner lens will still mount up no problem. Basically after I cut the retaining clip from the headlight housing, I just kept cutting tabs off the clear corners until they flushed up to the headlights. The mounting screw on top basically keeps them installed on the truck, those clips on the inside just basically keep it secure against the lower portion of the corner lens. Here comes the rigging part. I went to the store and got some 3M Heavy Duty two sided tape, and stuck it on the headlight where the retaining clip was. I think it took two or three layers of it to make them snug. Then voila! My truck had clear corners! I should've taken pictures of the process, but I wasn't sure if it would turn out good until it was all done. They are actually very solid, and line up perfectly. When I was researching clear corners, most people that have them for their earlier Tundras complained that they were a little loose on their trucks. My only complaint is they have a little bulge on the sides for reflection purposes that the earlier OEM Tundra corners had also, but the 2005-2006 OEM corners are smooth with no bulge. Just a minor gripe. Other than that, no problems with fogging up or anything.
Here is the finished product...
