1 - 7 of 7 Posts
I'll start out by saying that I've only been driving this truck since Friday afternoon so what I'm experiencing may be completely normal as I've never owned a Toyota. Truck is a certified pre-owned 2006 Tundra access cab SR5 4x4 V8 with 46500 miles.
When I apply the brakes, I get a click that seems to be coming from the front end area. I've read other threads about a clicking that comes from the brake light switch, but this seems to be coming from much more forward. I'm thinking it may be along the lines of the pads shifting in the caliper. According to the inspection report the truck had the front rotors turned and the pads replaced. It will not click when pressing the brake pedal at a stop, only when moving and then stopping.
Any other ideas of what to check?
same frikkkken thing was happening on my 02 and u have no idea how hard it was to get it diagnosedd... off road shops cheked everything and all said all is goood ,EVEN STUPID DEALERSHIPS SAID ALL IS GOOD AND COULD NOT DUPLICATE PROBLEM,,, i kept on getting the cliks on the front of my 02 tundra.... i had chekedd every friken bolt at the bottom. eventually my brake pads needed to be replaced..... i call my mexican budddy he changed the brake pads on the backyard and the cliking stopped completely everything is solid up front when braking not like before where it seeemed the pads were moving. replace the brake pads and make them fix it. AND NO IT IS NOT NORMAL!!
1 - 7 of 7 Posts
