1 - 7 of 7 Posts
I have been hearing and feeling a clunking noise below and in front of my feet when going over speed bumps, over dips, or accelerating from a stop. According to the receipts I have, my Dad (previous owner) had taken the truck to several shops, and nobody knows what the problem is. Any ideas?
2004 Tundra Double Cab
80k miles
Texas Edition
2wd 4.7l V8
*Transmission Mount and crossmember
*U-Bolts on leaf Springs Loose
*Cab Mounts Loose
*Steering Rack Bushings going bad or steering rack itself.
*Rear Drums Sticking
My truck clunks because Crossmember is broken from where the transmission mount bolts into.
+1 for trans cross member bolts. I only had 1 of the 4 left by the time I figured it out.
You get a pretty good clunk if it's a U-joint. Try sitting still and shifting from park to reverse to drive and back. See if it does it.
Check your ball joints.
1 - 7 of 7 Posts
