Thanks!Yes. Just remove the original (one set screw) and then install the new autodimming mirror. The new mirror has a wire that plugs right in the overhead console with a trim strip that hides the wire for a neat, good as factory look. I paid $229 for mine locally but I see www.tundrapartstore.com has them for cheaper. This one is an easy do-it-yourselfer as are other options like rear-view camera because the new 2007 are completely prewired.
I have looked at my console and am curious where the plug in is.Yes. Just remove the original (one set screw) and then install the new autodimming mirror. The new mirror has a wire that plugs right in the overhead console with a trim strip that hides the wire for a neat, good as factory look. I paid $229 for mine locally but I see www.tundrapartstore.com has them for cheaper. This one is an easy do-it-yourselfer as are other options like rear-view camera because the new 2007 are completely prewired.
That's because sonar sensors are probably already in there built into every Tundra at the factory. All you have to do is to take a hammer and a screwdriver and carefully punch in those little circular holes in the bumpers. Then slowly back your truck up against something until you hear a beep. Then come back here to let us know if it worked.Hmmm...I wonder if you could do the sonar aftermarket as well. I have yet to see that being sold.
I wonder how many people just ran out to their new tundras to check???:devil:That's because sonar sensors are probably already in there built into every Tundra at the factory. All you have to do is to take a hammer and a screwdriver and carefully punch in those little circular holes in the bumpers. Then slowly back your truck up against something until you hear a beep. Then come back here to let us know if it worked.![]()
Just kidding...don't do that. You didn't pay for it so it would be dishonest.
