1 - 8 of 8 Posts
Hi everyone,
Apologies if this issue has been covered before but could not locate. I will try to keep this concise, so it is easy to read and follow:
Vehicle: 2002 Toyota Tundra Limited (4x4, LSD with ABS) - 120k miles.
Issue: Noted a minor leak from the rear differential (Pinion seal), so decided to replace. I have replaced it 3 times myself already (used Mobile W75-90 for rear gear oil), and it continues to leak. I have tried everything, oiling it before putting in, sealing it, making sure it is flush...etc). The third time even tried to use the silicone around where the pinon seal goes in to create a rubber gasket, but still leaking. Brought it to Toyota and they told me the differential is pretty rusty, hence why the leak, and recommended to replace the whole rear differential. I don't believe what they say because the rust is on the outside and not on the inside, but that is just my gut feeling as I am not a mechanic.The leak is in the outer and not the inner part of the seal. I have seen a few videos of people suggesting sinking the seal further in etc, but I am hesitant to make any changes to avoid any damage.
The part I got was from Toyota and specific for my truck. I also double checked and seems to be the right part based on their website. (Stock code: 9031144007)
I have replaced the breather as well, in case that was the issue.
Any help from anyone experiencing the same issue would be greatly appreciated.
Nik
Hi everyone,
Nik
Hi,
Did you ever figure out the reason for this leak? I have exactly same issue on 2005 Sequoia.
Many Lexus and Toyotas
3 times you are doing something wrong or there is another issue. What did the drive shaft's seal surface look like? If it is actually leaking from the seal it is probably pitted and nasty. You may be able to get a repair sleeve for the seal surface if that is the issue. It has been a while since I have done a pinion seal but I have seen them put in backwards.
Also.... you will need to post some good pictures to get any better suggestions.
I was able to locate leak source. it was leaking thru rust spot in top part of differential case. the oil leak was coming slowly from top to down to the center differential seal/flange area and then by rotating flange/yoke was sprayed everywhere, so it looked like oil comes thru seal and gets splashed everywhere. Not good news but at least i know what is going on now. It is unbelievable what new England weather can do to metal, the walls of differential in this spot at least 4-5 mm thick.
I have the same problem on my 2004 (LSD /ABS)..
May I ask what you did you did to fix the leak?
did you replace the cover by any chance? or did you get a new differential
I'm battling the same problem. 2000 4WD Limited with A03A rear end. I'm in the midwest and the diff cover is pretty much rusted thru. I read you can weld a new one on. A new carrier itself is about 1100 $ OEM. I saw a use one on ebay for about 700 from out west that includes the diff, brakes, etc... My diff and axles seem to be in pretty good shape. Used would be my preference, but most junkyards in the midwest have carriers with the same issue mine does.
I have a 2000 AC 4WD and have the carrier w/o axle shafts. This one will fit, if you are still interested. I am in Raleigh, NC. and can provide pictures, etc... but not sure about freight.
1 - 8 of 8 Posts
