I discovered a leak last November. The leak ONLY occurs under pressure and when the engine is hot. Coolant does not pool underneath the car when engine is not running. That being said, when I discovered the leak last November, I heard squeaking. I just automatically assumed it was the water pump. It was time to replace the pump, so I just replaced the pump and the gasket. I reassembled the system. As soon as I filled the coolant, I noticed coolant draining down the coolant valley. I used silicone gasket sealer to seal the water inlet and stopped that leak. The thermostat and o ring were also replaced. I finally finished all the tasks and took her out for a test drive. Still the same coolant leak as before. Rented a pressure tester and discovered a large crack in the top radiator tank. Replaced the radiator as well to fix the leak. Last evening, I took it for a test drive. Still the same leak. I was pretty upset at that point. So I just let it sit until this morning. I took a quick drive to get it hot so that it would leak again. I put the pressure tester on it when it was hot and coolant is pouring from the passenger side on the bottom of the engine area. I cannot tell where the leak is coming from, but it seems to be originating just above or behind the alternator. It is leaking onto the alternator pulley and being flung all over the engine compartment via the serpentine belt. I’m about to take it to a mechanic, but I figured I would get some opinions here first. Approx 195,000 miles
