Does anybody know excatly where the coolant temp sensor is on a 02 Tundra??? mine is toast... and im wondering if I can replace this myself??? any advice would be appreciated. :tu:
My 02 v8 set a code for coolant temp. sensor after header install. It turned out to actually be an 02 sensor. Just a thought to possibly keep you from running around in circles like I was.
btw, the dealer replaced two 02 sensors per a tsb. When the temp sensor code came up, they instantly assumed it was an 02 sensor,and they were correct. so this may be a fairly common thing.
