I just purchased my 6" RCD lift (YES!) and am buying my rims/tires today. It says use at least a 4.50 backspacing so i assume the -12 is best but just wanna make sure.
I am going with the 35x12.5x18 tires and some 18X9 rims but they have 3 different options, they are as follows...
+18mm has 5.71" backspacing.
-12mm has 4.53" backspacing.
+30mm has 6.18" backspacing.
Pics to come!!! :spy:
I have the RCD kit too and my wheels are -12mm. They work fine but the rubbed on my sway bar like crazy, so I took it off. The truck handles much better and smoother without it. Good luck with the lift.
Oh and I think the kit says a MAX of 4.5" backspacing.
I got 20x10's on 4.5 bs and the only thing i rub on is the frame some times at full crank if im on a angle and my wheel well
