I have the 07 DC Limited 6.5 bed with the factory 20" wheel upgrade. Comes with Bridgestone Dueller HT tires. The sticked on the driver door panel says 30 psi for front tires and 33 psi for rear tires. I have been driving my truck for about a month and never checked the actual pressure until today. The truck had been sitting cold for an hour or so, outside temp was 70 degrees at the time. Both front and rear measured 37 psi with a fairly good quality hand-held brass dial gauge.
I couldn't figure out why the dealer would have overinflated the tires so I let some air out until I hit 30 front and 33 rear. The front tires actually look a little more flat than the rear so I am wondering if I did the right thing. Why would the front have less psi than the rear? Wouldn't you want more psi in front to handle the weight of the motor? Another odd thing is the TPM warning system didn't go off even though I lost 7 psi in front (23% of factory target value) and 4 psi in rear (12% of factory target value). Just how much air do you have to lose to get a TPM warning? Do I need to recalibrate my TPM now that I let some air out?
