I bought the golink that works with my ipod touch. it worked fine with my 2000 silverado. then i put it on my wifes 2001 camry:mad:. it will not connect at all. I looked in the fuse box and all fuses seem OK, i did a cont check on them as i pulled them. I bought this scanner after pepboys said they couldn't read my port last week. so now i'm thinking i have a connection problem on the port. also, is there another fuse somewherei missed, for the obd port?
so, I found a pinout of the port and my question is this? if i cant get power from the port, what should i look for next. and if there's power, then what. thank you for your time too.
EDIT....I found another fuse box on the left side of the dash, replaced a 7.5 fuse on the OBD post. got the code OF P0401.....now heading to another thread. thanks for looking.
Did you get the GoLink (now GL1) to work on your vehicle? Do you have any positive or negative comments?
