crutchfield has our truck listed in their online configurator. it will tell you what will fit. only 4 different nav systems are said to fit due to the depth. additionally, here are the details they state about installation:
Installation Details
Modified Fit - Requires Modification
Installation Details for your 2007 Tundra
» To install this product, you’ll have to modify your vehicle.
» You will need to fabricate a mounting kit in order to install your new receiver.
» A wiring harness is not available. You will need to splice into the factory wires.
» Bypass your factory amp by running new speaker wires from the stereo to the output side of your factory amp.
» If the factory radio is replaced, the factory AUX input connection will be lost.
