Hello everyone,
I have had an ongoing nuisance with my check engine light sporatically popping up on my dash. I originally got the cylinder #6 mis-fire light many months ago... i moved the coil pack, and no difference... i've changed the fuel injector because it looked like it was leaking while engine was off, still no luck.(while i hanged the injector, i cleaned the throttle body). i even changed the ECT sensor! seemed to work for two days but alas, the light came back on.
The engine symptom is this... This light used to only flash during initial starting of engine.. the rpm would float up and down a range of 2-300 rpm for about 10 seconds, then it would smooth out and i'd be good to go. This happens about 60% of the time, other 40% it starts fine. Just today, the engine sputtered slightly while i was driving, and the check light was flashing. it seems to be getting worse slowly but surely.... i need your help!!
another side note.. about every time i fully fill up the gas tank, after it shows its completely full, the gauge would drop to completely empty for about 5-10 minutes and then creep back to normal. would this be related to whats going on? or something totally different?
i changed my spark plugs about a month before all this started happening, so i'd say the plugs(which are manufacturer spec plugs) are less than a year old. should i change them all out again since ive done a few of these fix-ups?
Help please!!
Help please!!
