RS SERIES – The Most Popular System offering Height & Ride Adjustability
The RS coilover system is a 36 way dampner and rebound adjustable monotube full coilover system. The setup has seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times along with pillowball upper mounts or top mounts on most applications. Mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust. Rebuildable and serviceable in the US.
APPLICATIONS:
94-99 - Avalon - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
02-06 - Camry - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
07-11 - Camry - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
92-96 - Camry - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
97-01 - Camry - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
00-06 - Celica - Height & Ride Adj. - w/ Fr Camber Plates
90-93 - Celica - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
94-99 - Celica - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
90-93 - Celica All-Trac - All Teac - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
03-08 - Corolla - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
88-02 - Corolla - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
00-05 - Echo - Height & Ride Adj. - w/ Fr Camber Plates
85-86 - MR2 - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
87-89 - MR2 - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
91-95 - MR2 - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
00-07 - MRS - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
91-99 - Paseo - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
04-09 - Prius - Height & Ride Adj. - w/ Fr Camber Plates
10-11 - Prius - Height & Ride Adj. - w/ Fr Camber Plates
85-99 - Starlet (FWD) - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
86-92 - Supra - Height & Ride Adj. - w/ Fr & Rr Alum. Top Mounts
93-98 - Supra - Height & Ride Adj. - w/ Fr & Rr Alum. Top Mounts
95-99 - Tercel - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
05-11 - Yaris - Height & Ride Adj.
DRAG SERIES
D2 Racing Drag suspension kits greatly reduce your 1/4 mile time by offering increased traction properties through the use of drag specific dampening and spring rates while still retaining 36 ways of adjustment.
APPLICATIONS:
DRIFT SERIES
D2 Racing Drift suspension kits provide specially designed mounts, helper springs, and drift spec spring rates and with matched dampening. Inverted monotube strut design, 36 way adjustment and 55mm piston (for MacPherson applications) combine to give you the ultimate control over your drift.
APPLICATIONS:
83-87 - Corolla - Coilover Rear - Height & Ride Adj. - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
RALLY SERIES
D2 Racing Rally suspension kits offer steel mounts, elongated spring and stroke with matched dampening properties. Inverted monotube strut design, 36 way adjustment and 55mm pistons (for MacPherson applications) designed to withstand the toughest rally conditions.
APPLICATIONS:
TRACK SERIES
D2 Track Racing coilovers are designed for the circuit track enthusiast determined to go fast. Increased spring rates with more aggressively valved dampers and a larger, heavy-duty piston construction add up to a suspension system that out-performs competitors. Large 52mm bodies increase oil capacity and the aluminum construction decreases weight to help perform at the limit.
APPLICATIONS:
AIR SUSPENSION
D2 air suspension is designed as an application specific bolt up kit including dampening adjustable shocks. Kit Includes:
•5 Gallon Air Tank with 9 X 1/4 Port
•High Speed Compressor
•Sunbberf for Motor Use (4)
•High Pressure Hose for Motor Use
•High-Tech Silencers Plate Base
•120-150 PSI Pressure Switch
•Paddle Valve Switch (2)
•200 PSI Dual Needle Gauge
•Paddle Valve Switch and Gauge Bracket
•35M 1/4 Air Line
•10M Power Cord
•Fuse Box
•Fittings
•Shocks (including Top Mount and Shock Body) with 36 Levels of Adjustable Dampening (4)
•Air Bag (4)
•Installation Manual
APPLICATIONS:
94-99 - Avalon - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
02-06 - Camry - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
07-11 - Camry - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
92-96 - Camry - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
97-01 - Camry - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
00-06 - Celica - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates
90-93 - Celica - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
94-99 - Celica - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
90-93 - Celica All-Trac - All Teac - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
03-08 - Corolla - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
88-02 - Corolla - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Pillowball Alum. Top Mounts
00-05 - Echo - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates
85-86 - MR2 - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
87-89 - MR2 - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
91-95 - MR2 - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
00-07 - MRS - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
91-99 - Paseo - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
04-09 - Prius - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates
10-11 - Prius - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates
85-99 - Starlet (FWD) - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
86-92 - Supra - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr & Rr Alum. Top Mounts
93-98 - Supra - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr & Rr Alum. Top Mounts
95-99 - Tercel - Ride Adj. by Adj. Shocks & Height Adj. by Air System - w/ Fr Camber Plates - w/ Rr Alum. Top Mounts
05-11 - Yaris - Ride Adj. by Adj. Shocks & Height Adj. by Air System
GO TO NOPI D2 Catalog for model specific details
Contact the salesmen below or PM me for "TUNDRA SOLUTIONS" deal including FREE FREIGHT
