Does anyone have a Dakota Digital Fan controller in there truck? If so what sender option did you use?
Discussion Starter · #2 ·
Alright so I figured out I can't use the stock coolant sensor so Ill have to buy a dakota digital one, to use as a deciated sender. My question is does anyone know the size fitting it is for the one wire coolant temperature sensor located on the intake manifold? I know when I put my aftermarket oil pressure gauge in, I needed a BSP to NPT adapter fitting.
These are my options fitting wise.
Water/Oil/Trans Temperature Sender
