Hello everyone. Please move if this is in the wrong area. I recently replaced my OME leveling shocks (front) with bilstiens. Once i started the truck i had flashing 4 hi and 4 lo, solid vsc, abs, snd brake. Found that i busted one of the abs wheel sensors. Replaced it and the brake went away but still have abs, vsc, and flashing 4wd lights. 4wd does not work. Spreadsheet says unknown cause. Dealer wants 125 to hook up the computer. Do you think this just needs reset with the computer or is there another issue like damaged vaccuum line? Thanks! Its a 14 tundra with 5100 set at lowest level 20" wheels and 33" tires.
Most auto supply stores will read ( and clear) the DTC codes for free. Once you know what the codes are you should be able to narrow down the problem.
