I'm new to the group here and have a problem with my 2008 Tundra 5.7.
As I was driving down the road towing a small trailer, the following lights came on...
Check engine light (NOT flashing)
VSC (Flashing)
Traction control (NOT flashing)
4 Lo (Flashing)
The truck runs and accelerates normal except it won't shift past 4th gear. Doesn't matter if I am in DRIVE or S mode. It is NOT in limp mode. I checked the back up light fuse and it is good. Anybody have any suggestions?
Discussion Starter #2
Just did some reading about someone who had a mouse problem. Mice chewed up wires on a knock sensor? Sound right?
Discussion Starter #4
Codes read. Comes back as "P032D Engine Knock Sensor 3 ckt". You can see evidence of mice in the general vicinity. There are a bunch of knock sensor codes so I don't know what this exact one means but I know it isn't good.
When my AIP died it went into limp mode for about 30 mph tops with the same type of light indicators.
I’ve got this exact same problem but the dealer said it was a solenoid I’m the tranny according to their code. #4. Maybe they don’t know what they are doing?
