I am not positive if it is the same as mine because I have an 03 but there is a box under the dash on the drivers side that says light relay or something like that (forgive me I disabled mine about 2 yrs ago) and look for a white with black wire. I disconnected the plug from the box and removed the whole pin and wire from the plug so it could be connected back normally but you could just cut the wire and that is it. My friend did it on another Tacoma and I am pretty sure it was an 01 and when he first turned on the lights the bright light indicator came on and then after he turned off the lights and cycled the key off and on it was fine and the bright light indicator did not come on again.
