OK, so I had some free time today and decided to do a test fit on my 35/13.50/18's (325/65/18). I used my full size spare rim and the tire I bought for a spare (Hankook Dynapro M/T). It took 70 pounds of air to get it to pop onto the rim. It fit WAY better than expected. I have to remove the front mud flap for full front articulation. I will need to trim the body mount slightly and thats it. Plenty of room between tire and UCA and it isn't even close to the skid plate. (see pics below) Whoo Hoo!!!
at full articulation it is close to body mount and will need a mild trim
never even came close to skid plate
gotta pull front mud flap for full articulation
not even close to the UCA
straight ahead plenty of room
fills the wheel well in very nicely
what amount of lift do you have installed?
I have a 09 tundra RW with factory 17", I added a leveling kit and squezzed 305x70R17 on it, I have since ordered a 3" body lift, 18x8.5 rims and 35x12.50r18 toyo M/T tires - tires are not here yet but as soon as they are lift is going on followed by the tires. if they dont fit - that is what the cutting wheel and torch are for!
badguybuster
What offset are your rims? Looking to run the 325/65r18 and want to make sure I have enought space not to rub the UCA. what is the lift you have on there also? thanks
