1 - 8 of 8 Posts
Since my rear differential is an LSD, I'll use Royal Purple Max Gear. It has an LSD additive, right? My question is can I use that in the transfer case and front differential too or should I use a different gear oil?
Thanks,
Scoob
what truck do you have?
Discussion Starter #4
Then I could also use Mobil 1 75W-90 LS, but again, can that be used in the transfer case and front differential as well?
Thanks,
Scoob
Yes, that's what I used in mine. Front and rear diff. and the transfer case.
No issues.
so are all 05 and up tundra lsd's only or how can i tell what kinda diff i have besides just spinning tires
Here for the long haul!!!!
Used the Royal Purple in both diffs and my transfer case and it shifts so much better now compared to the stock oil. Can't go wrong with Royal Purple.
1 - 8 of 8 Posts
