So i had CEL with said Bank 2 sensor 1 out(pass side 1st sensor). Got new Denso from Rockauto. Went to install it and f**** up. Used PB blaster for half day, warmed up for a minute, took O2 sensor socket and managed to turn it -1/4 turn, then +1/4, turned it forth and back dozen times but it would only move that 1/4 and not more. So after 49 minutes i pulled out sawzall and cut the back off O2 sensor so i could use deep 7/8 socket as special slotted socket was slipping. Once i got deep 7/8 on with 16" bar it came out but i what i saw was destroyed threads. And no i didnt just backed it out - i went in and out but that didn help apparently. It wasn't rusted in - metal was like fused/welded together and metal on O2 sensor gave way. Now i have these left over pieces wedged in the O2 sensor "socket" threads on the exhaust pipe. Couldn't find tap/die set in Homeless depot/Lowes of that size. My temporary fix is 1/2 bolt in the hole and some aluminum flashing and 2 steel ring clamps holding it. Got to go to work 3am tomorrow hope the temporary fix will hold.
Am i looking at header removal to fix the threads? (seems to me, so already sprayed header nuts with PB)
P.S. bank 1 sensor 1 looks fairly new with new label on the wires so that was changed not too long ago.
P.P.S threads on the pipe dont look so bad as on the sensor - only top row is partially filled with fused metal from destroyed sensor threads, so new one doesn't catch the threads to start going in and its a biatch to access
