21 - 40 of 75 Posts
Re: HOW-TO: Check the Automatic Transmission Fluid Level
Well, I looked and couldn't find a good way to get to it. The best idea we came up with was using a syringe to shoot it up in there in the refill hole.
But, I ended up taking it to the dealer and he topped it off for me.
if it happens again, you could use a differential gear lube pump. it simply pumps the fluid from a lower level to a high one. it how they get oil in the differential, found at all auto part stores.
I do not see it mentioned anywhere in the owners manual about replacing the tranny fluid...do we not need to do this in the 2006 Tundra? Seems kinda strange but Im assuming it never needs it, according to the book.
It only mentions changing differentials and transfer case fluid if towing...when they say "towing" do they mean everyday, once every couple weeks, or what?
thanks for the help in advance :)
I accidentally drained some transmission fluid. It seems to be a common problem. I understand that the 2006 tundra does not allow you to top off the level. I lost less than half a quart, will it be allright until my next scheduled transmission check in 20,000 miles?
Any issue with using Castrol ATF Import Multi-Vehicle instead of the Toyota ATF WS for a 2007 FJ Cruiser? That was the only kind I could find at the local parts store and I was almost 75 miles from the nearest Toyota dealership.
Also, I am going to change it out for the ATF WS asap. Any issues driving on the Castrol for about 75 miles, til I can get to the nearest dealership?
So has anyone with an 06 done this? My car was cold and like an idiot, I unplugged the drain bolt. I'm not exactly sure how much drained out but would like a way to top the thing off. I live 2 miles from the dealership, can I drive it to get it topped off or is there a way I can do this myself?
Buy a cheap pump sprayer, buy atf from Toyota fill it. fill plug on the side half way up, fill till it overflows when it stops overflowing its done. Why did you remove the drain plug:confused:
INFO:2005 A750E/A750F Transmission
I was in a hurry and wasn't paying attention. I was extra careful when I changed the oil the first time but just careless I guess. All the other cars that I've changed oil on it's just loosening up the first drain bolt I see. Lesson learned. Thanks!
Is the fill plug the 22-23mm bolt on the passenger side?
Hi there. First post. Please be kind. I have a 2000 Tundra and am getting strange readings on my tranny dipstick. The picture shown here in your post looks right. However, when I check hot (running in park) the fluid only hits in the cool range (near end of stick). When checking cold, the fluid is much further up the stick, near the hot range. Is this not the opposite of what I should expect, or am I losing my mind? Thanks.
Toyota Tacoma 2005 Acess Cab Automatic Transmision Oil Fluid Change:
1. Buy dealer oil $4. per quart, I bought 4 qts, but only used 3qts.
2. Buy 24mm Socket for fill
3. Buy valoline plastic oil pump for $6. i think the Gallon size screw cap is best for the deal oil bottles.
4. after a drive to heat oil up, remove fill socket, then remove drain plug (not the plug that has "CHECK" on it.
5. let the transmission cool down!!!
6> replace drain plug, and pump fluid into fill plug it is a 24mm socket on passenger side of transmission, rear of trans behind the 2nd section.
7. add 3.2. qts then screw fill plug( i left somewhat lose in case i have to go back and add some. Turn on your truck and warm up your truck; move the shift handle from park to low to lubricate oil throughout engine.
8. after temp is hot in transmission like 124 degress farienhiet. remove the "check" plug with a 5MM hex wrench while the engine is on!!!!!!!!!!. This will allow the excess fluid to drain. if nothing comes out you have to add more oil. ( I put in 4 qts of oil and 1 qt flushed out the pan from the "check" plug. So next time i will only put in 3 qts of trans fluid.
9. go back and tighten everthing up when you trans fluid is level.
I saved over 140 dollars:)
Good luck.
How about the procedure for checking the trans fluid level on 2005 models with no dipstick!
I tried yesterday while under there changing oil and greasing drive shafts. I have two plugs on the trans pan one a plain plug at the rear (drain?) and one with "check" stamped in it with a hex allen head. I removed this "check" plug assuming it was at the bottom of some sort of tube extending at or above the specified level in the pan. Logical, I thought, like most things Toyota. WRONG!! I got a face full of oil before I got it threaded back in. I figure I lost about a quarter pint of oil at most. I doubt this will have any effect, but I would like to know the correct procedure in any case for peace of mind. Anyone know the correct procedure, and where the fill hole is? I found what looks like a fill hole plug, but it is in the tail shaft housing between the trans and transfer case. Is that it? Thanks in advance for your help.
My husband just told me he did the same thing to my truck...He accidentally pulled the wrong plug. I am going to take mine to the dealer and have them do what they need to do...I don't want to pay the money, but I'm worried about trouble down the line. what became of your issue? Did you leave it go?
Thanks guys. Your comments made my discission. I will NEVER buy a Toyota. I was really thinking about it. As far as I went and got pre-approved for the autoloan to make it easier. A transmission without a dip-stick and a life long oil life. Theres metal particales in the tranmission fluid due to gear wear. Overtime they build-up and will clog the filter if your lucky. Worse case plug the valves cause internal damage nothing big just about $1500 to $3000 to replaced or overhaul. Who wrote the manual? Sounds like a way to make money. Hope you dont plan on driving over 100,000 miles if you use the truck as advertised. Thanks for the info and steering me in the right direction, buy domestic.
Yu are on the wrong forum dude.:der:
21 - 40 of 75 Posts
