Mine came without them but I added them about a month ago.I have never seen a TRD Tundra without the rubber Door Sill Protectors. One of the service guys said that all the TRDs come stock with them. My TRD DC did NOT. Has anyone out there gotten a TRD without them ??????
They are adhesive backed. Clean the surfaces well, work in a well lighted area, follow the instructions and take your time. The adhesive is very strong so once they're down, they're down for good.Mine didn't come with them either. I want to buy some - does anyone know how they attach? Are they magnetic? Do they stick?
Mine came with rubber floor mats and had the sill protectors. I might be a regional thing too.Mine came with the OVER priced carpeted floor mats for $178 but that INCLUDED the sill protector. I think that is the only way to get the sill protector from the factory is to order the carpeted floor mats.
I only need that cleaner for this very small jib... I sure do not need a gallon can!3M™ Prep Solvent-70
Water-based; removes oil, wax, grease and silicone from primed or painted metal surfaces prior to coating.
THANKS... will do!You don't need it. Use Windex.
You don't need the squeegee. You can just use your hands, being very careful to not get any bubbles when applying (or a wood block wrapped in a cloth). Personnaly I wouldn't use Windex. Use isopropal alcohol, that way there is nothing left (residue) and you will get great adhesion.THANKS... will do!
I wonder why the info sheet says, "Do not smooth part with hands."? ("Using a felt block; squeegee the...")
Mike
I used a folded up shop rag and it worked fine. I got a few small bubbles but I was able to work them out the the edge pretty quickly.You don't need the squeegee. You can just use your hands, being very careful to not get any bubbles when applying (or a wood block wrapped in a cloth). Personnaly I wouldn't use Windex. Use isopropal alcohol, that way there is nothing left (residue) and you will get great adhesion.
Where do I get the 3M bra stuff to install on the front of the hood? I live in Vegas where there is so much dirt & little rock pebbles throw around from the job sites & trucks that it's a must around here.My TRD didnt come with sill protectors. I had some 3M clear bra material left over from my install so I used that to do my door sills, front and rear.
