I have a 2002 Tundra SR5 with a 3.4 L engine and about 455,000 miles. I recently purchased a replacement passenger side door from a salvage yard that was allegedly the correct door. Fortunately the door fit fine. Unfortunately, the terminal blocks/connectors that come in from behind the cab kick plate for the wires to the power locks, the power window, and the power mirror do not match the originals that were on the wiring harness on the old door. So the window is stuck in the up position, the mirror can only be adjusted by manually moving it and the lock can only be engaged by manually flipping the switch on the door or with the key in the lock (I changed the lock cylinder from the old door). Anyone have any ideas which wires go to which device? Would I simply be better off taking the wiring harness off the old door? Trying to find the easiest way to do this.
