This was an easy and inexpensive mod with significant results. My truck has an adjustable coilover lift, 2.5" lift set at just about 2", just as many other members have. My front swaybar kind of lost its effect after the lift and I gained a small amount of body roll on the front of the truck. You can notice the hoods angle when you take sharp corners at considerable speeds.
Here's what a normal, non-lifted sway bar link looks like...
Photo courtesy of BAD BONEZ BJ.
Notice the proper squish factor.
Here's what mine looked like...
note: polyurethane bushings seen here are reused later.
Here's what mine look like now...
note: this is after 2 days of normal driving to allow settling.
Notice the natural angle and better squish factor.
Anyways, I'm not selling you on this product, just showing you how to install it :thumb:
Tools needed:
* Downey H.D. Sway Bar Links, found here
* 3/8" Torque wrench w/ sockets - 14mm deep, 17mm deep, 19mm
* 17mm Open end wrench
* 6mm Hex key
* 1/2" Drill or Drill Press
* 5/8" carbide drill bit (pansy bits need not apply)
* Silicone grease
* PB Blaster (or similar) for the bolts
* a cheaper spray lubricant for the drilling
Step 1, Prep work.
Block rear tires, parking brake, neutral gear, key at ON position so you can turn wheels while under the truck. Lift front crossmember so front wheels are just off the ground.
Step 2, OEM Removal.
You'll need the 14mm deep and 17mm deep sockets here.
Remove the sway bar as seen here...
Now remove the OEM end links...
The removal of the lower nut is a bit tricky, the head is captured inside the little boot, so it turns with the nut after it's loosened. You have to hold the bolt end using the 6mm Hex key and turn the nut off using the 17mm Open end wrench. It's a small PITA...
Another angle of the captured bolt...
New H.D. link doesn't have this captured bolt, instead they used an eyelet with a large bushing inside...
Step 3, Drill the 5/8" hole.
The sway bar is one of the hardest metals on your truck, if not the hardest.
At one point, the bit I used turned red at the tip. The bar was also too hot to hold even at the center with your bare hands.
You may be asking: Why drill this larger hole?
It's in the instructions, do it.
No really, it allows more play for the larger diameter stud used in the new links.
But, the factory hole in the sway bar is plenty large enough for the new stud, you can probably skip this step.
Step 4, Install the new links.
Reinstall the sway bar C-channel bushings. The kit comes with new ones, but I already had the Wheeler's anti-sway poly kit, so I opted out of the new Downey bushings and they took off $25 from the H.D. kit price.:tu:
Take a look at the new links, much beefier than the OEM links...
Downey's H.D. End Links are galvanized to prevent corrosion.
The new H.D. links use stronger hardware as well. You'll use a 17mm nut on the wider diameter stud as well as a 19mm nut on the 1/2" bolt holding the link to the mounting point.
Here's a photo with the discriptions...
Step 5, Tighten and Torque.
14mm nuts to 19 ft lbs (sway bar c-channel brackets)
17mm nuts to 14 ft lbs (new link studs)
19mm nuts to 25 ft lbs (new link mounting bolts)
Now, test out your hard work! :devil: Drive around, hit some bumps, take some turns, go and check the torque on everything. After a few days, if you so desire, recheck the torque again for safety.
References and thank yous:
I would like to thank oneprblmcat for his very helpful thread: http://www.tundrasolutions.com/forums/1gen-tundra/128145-front-sway-bar-linkage-snapped/
I would also like to thank BAD BONZ BJ and his two sons for their help in completing this project. :thumb:
Tools needed:
* 6mm Hex key
* Silicone grease
Step 1, Prep work.
***I encourage you to WEAR SAFETY GLASSES***
You will need some patience or a very high RPM drill or impact drill here. At one point, the bit I used turned red at the tip. The bar was also too hot to hold even at the center with your bare hands.
