1 - 12 of 12 Posts
I'm wondering if anyone out there has an 04-06 Double Cab and has drilled into the roof of the cab to install either Thule or Yakima roof tracks. I want to be able to carry a kayak and surfboards but I have an Access roll-up tonneau cover on the bed.
I stopped in to the dealer I had the cover installed at and they told me there isn't much I can do in the way of adding ladder racks or any other kind of rack for over the bed because of the way the cover is installed.
Anybody have some suggestions?
No need to drill your roof - Yakima and Thule both make rack systems with feet that sit on your roof. You've checked those out and don't want to go down that path?
I had a great set of Thules on my 2000 Tundra access cab. These locking metal brackets came with the fit kit - they were built perfectly to snug into the door frame, which is what held the rack feet in place on the roof of the cab. They were buff and solid, and you could move them fore and aft a little bit too.
Later I drilled through my camper shell to mount a different set of racks to the roof of my camper. Did this because the wind noise of the racks over the cab was a little annoying.
My personal opinion is that mounting anything on the roof is a bad idea. Have you ever leaned on it and had the sheet metal cave in?? I have a pretty good dent in mine from just leaning on it with my arm while washing the roof.
Resident Curmudgeon
See if a TracRac will work for you.
Super Moderator
I have a 00 model not a 04-06 but, I've drilled through my roof to install a custom roof rack using thule feet, thule bars and a heavy duty palet rack shelf.
Here's a link to what I did:
2000 SAC'ed Tundra
The wind noise must be horrendous with that, yes???
How about taking the liner down and sticking DYNAMAT onto the ceiling to reduce wind noise?
1 - 12 of 12 Posts
