2004 Toyota Tundra Double Cab .....OK was on a roadtrip yesterday and ran the truck pretty dry...low gas light was on for 10miles but truck NEVER stuttered or stumbled....filled up the truck...took 23 gallons!!!....went to start up the truck...it started then quickly died...attempted several times with the same result. Only way I was able to keep it running was to keep a little pressure on the gas pedal. Thought it might be air in the line or maybe even "crap" pulled up into the fuel filter preventing full flow?...if it was the fuel pump I would think I'd have problems delivering fuel even if pressing the gas in fact more of a problem when asking for increased flow.....was able to run it another 200miles home while never letting fully off the gas (ie keep foot on gas even when stopping at lights/signs)....got it into the driveway and as soon as I took my foot off the gas it died...same symptoms starts then quickly dies.....I'm thinking fuel filter???? anyone else have similar problem.
One time in Death Valley (specifically way out in Saline Valley Hot Springs) I started up to drive home on Sunday and found a brilliant array of alert lights on. Not the place you ever want to see that! VSC, Trac, etc. All was fine driving out there. Made no sense. There was a guy with a steampunk J40 with a satellite dish on top just a couple hundred feet from me. I figured he knew a thing or two about Toyotas. Mine is a 2005 Sequoia Limited 4WD. He came over, pulled the codes, went back to his rig, fired up his laptop, and walked back after 5 min. He asked, "When you filled your tank to come out here, you topped it off I'm sure, but did you give it an extra squirt?" I said yes indeed as we are 3 hours off of pavement and... He said it appears that all this is, is that I filled the neck of the tank, wetted the charcoal canister, and now the system is detecting air flow issues (vacuum, something I don't know but makes sense - its like plugged sinuses). He said once that dries out the lights should go out and it won't affect driving out of here. So I did and it resolved. I have never given the extra squirt again.
Don't know if this is your deal. Sounds a bit different to be sure, but I thought I would share this.
