1 - 13 of 13 Posts
There was a thread recently on TN about this. Apparently it is caused by an emission device and the noise can be eliminated by using something to insulate the mounting. Do a search over there for it and they have the full How-To in the thread.
Please post a link to this thread so that everyone can look at it!!! Thanks, JB :ts:
Hi,
Mine ticks like there is not a drop of oil in it. Only 500 miles on the truck. My 2007 is WELL PAST the TSB. So Toyota.......what is causing mine to tick like a broken sewing machine?? ah ah ah Don't say it's normal, because that would imply that the one's that don't tick would not be working correctly.
this fix works pretty good. Its much quieter going threw a drive threw or something like that.
the ticking in my truck doesnt really bother me, but i can hear it while im @ idle,so i may do this as well. did you use a rubber grommet for yours or what??
Yeah I used what I had laying around. It was a 1/4" thick rubber washer that fit good.
I didn't and don't have a ticking sound at idle like others describe, but I do notice a slight ticking sound when accelerating with the driver side window down. If there were other road noises you probably wouldn't notice it.
So I decided to give this a shot. Instead of the washers or cable ties, I removed the bolt and took a 4" section of preformed pipe insulation with an inside diameter of 1 1/2" and about 3/4" wall thickness. Sliced it the long way and slid it around "the part". This allows it to be separated from surrounding parts without being completely enclosed. The open slit faces the driver side fender.
So far I have not noticed the acceleration tick. But I will give it some time to determine if I am just "not" hearing things.
Just a different thought. :)
1. These engines are overhead cams...kinda like overhead valve "Solid Liifters"......Old technology: no hydraulic cushion to supress the sound of mechanical parts banging against each other. ..Ticking??? There's NO problem with "Ticking" in high performance engines.
2. These new engines NOW have reverted to "Timing CHAINS"...like the old days...back 20+ years... before timing BELTS. Chains were reliable, no need to replace them.....ever. ..but they weren't as quiet as belts. It took awhile for Toyota to figure out that the price of "Quiet" maybe wasn't worth the hassel of "keeping an eye" on the belt, and replacing it every 60-90,000 miles. TacoGuy
What he said,How soon we forget the original 4 banger, you think ticking:)
1 - 13 of 13 Posts
