Was wondering what the pros cons or if any effect what so ever would be if I were to cut the stock exhaust. I was told that it would make it louder which for now id be happy with untill I can afford an aftermarket one. If there are going to be any negative effects though I will not be doing this. All info will appreciAted.
http://www.toyotatundraforum.com/editpost.php?do=editpost&p=96579
It will be louder and you will most likely have two results First, your power band will be shifted up, meaning low end torque will be less but high end power will be greater(rpm). The other thing that will happen is that you will have in cabin resonance or "drone" usually from 1500-2000rpms. Good luck with your decision.
