I have a 2005 AC Tundra that started something last week. There's a faint, but extremely high-pitched, whistling sound (almost like tinnitus) inside the cab when the engine is running. It took a couple days to narrow down, but I've connected it to the brakes. If I press the brake pedal more than half an inch, the whistling stops, and within that 1/2-inch of travel, I can make the whistling change pitch, so the sound is mechanical, not electrical, like some electronics fixing to fail.
I'm assuming that it's a vacuum leak in the brake booster canister. THe brakes are, for now, working just fine. It's not audible within the engine compartment, only the cab. The question is, would this be a whole canister replacement thing, or is there simply a seal that can be replaced?
