Flashing traction light on 07 FJ Cruiser
4693 Views 5 Replies 2 Participants Last post by  mudfuel07
I've been driving my FJ for over 2 years with no problems however recently the light that comes on when you loose traction has been flashing as I'm driving down the road with excellent traction. The light comes blinks off and on aproximatley every three for four seconds. I've tried unhooking the battery to see if it would possibly reset everything with no luck. Any ideas on what could be causing this and how to fix the problem?
Did you just put on a new set of tires? Could be a sensor went bad too.
Ya. I just put a new set of tires on about a month ago. Do you know where the censor might be located at to check?
I believe that it's under the dash somewhere, I'm not real sure on the FJ. It senses when the vehicle is off level either side to side or front to back. The tires might also be a little softer than the factory ones, did you go larger with the tires. If you put any kind of leveling kit on it, that threw it off adn you'll need to get a zero point calibration from the stealership.
Thanks for the tips. I didn't go larger than factory on the tires but they are a softer tire than stock. I'm sure that was probably it.
I bet that's the reason, more sidewall flex doesn't make the sensor happy. Toyota should be able to recalibrate your sensor for you without a problem.
