05 AC w/ DRL:
so far i've cut the wire from the switch and spliced it into switched power and it still works as it did before.
i guess i get to search for the freakin green/white wire the goes to the relay and ground it?
the only green/white wire i found near the fuse panel so far is a pretty thick gauge. i highly doubt this is the one.
is there a better way to go about this?
