1 - 20 of 39 Posts
I took my 2000 Tundra into the dealer today for a recall inspection of the spare tire cross member and frame. Verdict is that it needs a new frame and cross member. The entire process will take a week once the parts arrive. Apparently they been doing Tacoma's for the last few months and have now started Tundra's. Anyone else in this same boat? If so, I'd be interesting in your experience with process and ending results.
Let me get this straight. They are going to remove the body, the engine, the suspension, gas tank and everything else from the old frame and transfer it onto a new frame. On a ten-year-old truck.
I'm anxious to hear more about this.
My 2000 Tundra with 236,000 failed state inspection due to 3 areas of frame rust. Especially rusted out on drivers side at the rear cross member. Was informed by Toyota that they will be replacing the complete frame on this truck. Really hard to believe they are putting this cost into a 10 year old truck. Went by another Toyota dealer this afternoon. There were 2 complete frames sitting in parking lot. Have to believe they are for Tundras
I went in a couple of weeks ago and got my frame inspection on my 2000 tundra after the brake warning klight came on. The proportioning valve was leaking so I lost pressure. I remember that the proportioning valve is covered under the rust recall. My frame failed instpection, they are replacing the frame and some other components.
The toyota mechanic said he has done over a hundred of them between Tacoma's and Tundra's. He said the other mechanic that does them has done more than him.
If you need a frame they won't let you drive it away for safety reasons, so the provide a rental car for free. Initially they said six weeks because it take a while to get the tundra frames, they have several Tacoma frames stacked up outside the shop.
The initial estimate was $5,800. Lots of other work not related to frame that I will take care of my self or have my mechanic do it for less or just let it go. The items that I will have them do are e-brake cable which broke when they took it apart. $295. Shifter cable (badly rusted) $310, all fuel lines $350, Transmission mount $110, rear bumper stops $165. I called Toyota customer service to see if they would cover any of these parts. The answer was no!
After they gave me the estimate I asked to look at the parts so I could deside what to replace and not. So they brought me into the shop and the cab is up on the lift and all the other parts are stung out on the floor in a farely neet pile, organized from front to rear as they were dissasembled. There was another Tundra next to mine also disaasembled.
Unbelievable no matter how you look at it!
WOW - just wow. Glad to see Toyota is taking care of the frame rust problem.
Interesting, I have a leaking proportioning valve on my 2003 tundra and just had the dealer order a new valve to be put in when it comes in in a few days. I dont think I can get this under the recall as I have no rust on my fram and live in a Western State, but thanks for posting about the valve because I could not find anyone else with this problem. I spotted mine with a small leak when I was under the truck adjusting the load bar the hooks to the valve after and AAL install.
im looking to buy a 2000 tundra from new hampshire and it's in the process of getting new frame. they have another on the lot that just got it and it looks great. they said once they get the frame though, it only takes a day and a half to do it. maybe theyre just fast
My 2000 has been in the shop since 12/30/09 waiting on the new frame. The frame arrived 3 weeks ago, and they are still in the process of getting all the bugs worked out before giving it back to me. Whoever says it takes less than 2 days is blowing smoke. I made them do a state safety and emissions inspection prior to me accepting it back from them.
about $4K to buy from them, about $600 cost for Toyota from suppliers :(
Got my 2000 Tundra back with new frame, 4 new shocks, and upper and lower ball joints just last week after being in shop for 12 weeks. Left dealership and drove 1 mile and lost acceleration and check engine light came on. Had to pull off to road side and get a tow back to dealership. Throttle body was indicator. Service had it reset and informed me probably due to truck not run for 12 weeks. No problems since. Truck is running and riding great. Still found it hard to believe that Toyota did all this work for a 10 year old truck with 236,000 miles. They also provided me with a rental vehicle for this time as mine truck inspection had run out. $2,800 paid to Enterprise. Still think I would have been happier with a buy back.
Our shop has done a few frames and it should NOT take 3 weeks. I did a frame job years ago on a T100 (bent frame from an accident) and it only took me 3 days. I'd say they are putting your job to the back burner.
Discussion Starter · #17 ·
Update on my replacement. They had it for a month and it's supposed to be done today. They called and told me the steering rack is leaking to such an extent it cannot be driven. Odd, given that the truck never leaked period prior to going in. They offered to replace it at cost ($400). Thoughts on if I should do this? My guess is that the seals dried up after sitting with no fluid for the month. Anyone have this issue?
I took my 2000 Tundra in last month for the inspection. They found a rust through hole in the side of the frame. Toyota is replacing the frame.
The dealer just called and said the frame is in, all I need to do is drop it off. It will take 5 to 7 days to do the job (the dealer has done 20 of them already).
Only problem I have is that they would give me a Corolla to use but I can't except it as it won't tow a 20 foot boat. I asked for another truck to use but they refused.
Oh well, taking the truck in at the end of the month to have this done.
I did pick it up today. The reason they had it for so long was that as they tore the frame down, they found more parts that needed replacing that were not included in the kit. Once they had a complete list of parts, some were back ordered, and I had to wait. Looking at the parts list, I got a new AC condenser/compressor, radiator, left sway bar link, rear shocks, fuel lines, fuel filter, rear cylinder bleeder, and control arms. They are also waiting on some wheel well trim that got ripped off in the parking lot.
Discussion Starter · #20 ·
They told me mine would be done in a week also. I also got the parts on backorder speach and it took a month. In fact I called them yesterday looking for the status and was told the part apparently 'just came in'. I'm amazed they replace your condenser - they told me mine was leaking and offered to fix it for 900$. Anyone have any contact info for Toyota corporate? Or perhaps if anyone ran into similar issues, how it got resolved. Thanks for your help!
1 - 20 of 39 Posts
