2003 Tundra Access Cab...just bought one week ago!
Okay, I've done tons of research but just can't narrow the result.
I've got a vibration starting at 30MPH and is not 1/1 rate to tire spin. It's like whooom-whoom every 3/1 rate to tire spin.
When ADD is activated 4wd the noise goes away! In 2wd I did the tape front drive shaft test and the vibration went away immediately.
Bought from dealer! Long story short, they said there was a vibration and that they wrong type oil was in there and changed front diff oil before my test drive...I noticed no vibration. I picked up 1 week later and 2min from lot vibration was apparent.
Did they put heavy weight gear oil in there? Would this cause front drive shaft to spin own it's own? Is the ADD trying to engage or not lined up? Leaky vacuum?
The front drive shaft should not turn when in 2wd...correct?
The dealer had it on a lift and on blocks in drive and sound test everything. They said the noise was coming from the front diff. I've heard that 03 production of the ring gear and pinion where rough and that a new front diff will fix this.
I think step one would be to change front diff oil to AMSOIL Severe Gear 75W-
90, GL-5 spec for hypoid gearing. This would eliminate oil type/problem.
Side Bearing? Front Bearing? Rear Bearing? Unbalanced Front drive Shaft?
Please let me the the steps to take to correct this annoying vibration.
Oh ya...this truck does have a 3" lift with 32. The drive shaft angles look fine, u-joints look and feel good...it's in the diff...right? But what inside? I will convert to manual hubs some day.
Thanks for your help...I've wanted a Tundra for years now!!
Cheers!
Cheers!
