Hi my fuel pump doesn't pump. There is a positive & negative wiring under the driver's side sill plate. Does anyone know what wiring wires are positive & negative. Tyvm
I talked to a master mech. If I do this it could mess up the fuel module. It could cause more problems. So I don't suggest this. Thank you anyway.
Discussion Starter #4
Hi everyone, I bought a Denso pump. It came with a new fuel pump filter that goes with the fuel pump. I primed the fuel system, several times. You can't hear the fuel pump because the gas in the tank muffles the sound. It started right up. Don't go with any fuel pump. Because it could have a different amount standards. It won't be built for the right specs. Denso is as heavy as the OEM. Cost for the pump and filter pump $120.
Thanks for the update. Was going to suggest it might be the pump relay as I've replaced several over the years on various vehicles to 'solve' pump failures.
