I have a 2002 AC
My 4WD light started flashing the other day while driving in 2WD and I lost 4WD. Through some gentle persuasion with a hammer, I got the truck into 4WD but now the light blinks all the time and the button is backwards. When I push the button in for 4WD the truck is in 2, and when I press it again to the 2WD position it goes into 4HI. I took the cover off the transfer case actuator (full of water as I'm sure you guessed) and cleaned and reassembled it. No change.
Can I manually move something to get the transfer case back in sync with the button? I suspect that's why the light is blinking all the time. I also can't get into 4LO because of this, but I never use that anyway.
