galvanic reaction, spark plug to block
My 05 DC Tacoma V6 4.0 is 10k overdue for spark plugs.
Question on galvanic reaction.
The block is made from Al the plugs some form of steel. Most anti-seize contains graphite (bad for Al).
Am I looking to much into this subject on the use of antiseize on the plugs and block to prevent galvanic reaction.
I have Zinc antiseize on order and both C5-A and High temp Nickle based instock at the house.
Loctite lists a recomendation of what type of anti-seize to use for the materials your using. Zinc is listed as a best choice for Al threads. Only problem (if it is one) 700 deg F max temp.
