I really need a backup camera for this beast. I checked and found Backup Video Pre-Wire connectors above the overhead console and under the bed, near rear bumper, just right of center.
After watching several backup camera installation videos on YouTube, a "Plug & Play" Backup camera and Mirror Monitor system was purchased for my 'new to me' 2007 Tundra from TailGateCamera ($269.99 on sale but now out of stock).
The factory type connectors at the mirror and under the bed plugged right up. Mirror has a solid green power indicator light that comes on only when reverse is selected but no image shows up in monitor in mirror.
Supplier said to check for four tiny corner Infrared lights at camera -you can see them light up if working; they were not. I checked and there is
no power on the factory connector that ultimately leads to the handle camera. Also, supplier said that I would not be able to measure the video signal with my multi-meter, that specialized (highly sensitive) equipment would be required.
https://tailgatecamera.com/collecti...p-camera-and-4-3-mirror-monitor-for-2007-2009
Has anyone else run into this issue or solved it without cutting and splicing wires in the factory harness?
Problem solved on the mirror wire harness by splicing the white 12V power wire to the purple, power to the camera, wire.
Supplier said it may be necessary to provide a ground to the camera negative as well but this was not necessary as I already had a good 'black wire' camera ground.
I checked engine compartment fuses #19 (30A), #20 (15A) also cabin fuses #56 & 57 (both 7.5A) just above emergency brake and all fuses were good.
Mark
