1 - 20 of 21 Posts
Anyone have a listing of where they have found grease fittings on an 05 Tacoma. Since I'll be under there changing the oil tonight, I plan on giving her a few squirts of lube as well. :D
For sure the driveline should have some at the U-joints and slip joints. I would suspect all the front end parts are sealed. Just look around for the grease zerks ... they are either there or not. ;)
I finally got around to changing the oil yesterday. Thanks for the reminder on greasing.
Discussion Starter #4
Glad to see you finally made it here? How many miles do you have? I changed mine 3k. And then went to the 5k miles that manual calls for. So I changed it again at 8k miles. Switched over to sythentic now.
I put Synthetic in at like 500 miles and changed it at 2000. Now at 5400, its due again.
Discussion Starter #6
Well this is a first for me...adding synthetic that is. I've never owned a car for more 50k miles. I get bored with them easily. Even if I like the car. Now that I own a house and getting married, I need to be a little more money conscious. The future wife tells me I need to keep this truck for 10 years. Ouch. Because she gets the next new car. I think I'll go out of my mind owning a car for ten years.
Well i just crawled under my XRunner to try and grease the Driveshaft. I found zero zerks on the shaft anywhere...so Maybe they went sealed on the shaft this year also..I am glad cause that was always a pain in the ass on the old truck
Retired Contributor
According to the manual and the pictures (05)
There are no zerk fittings. 2wd/4wd/access cab or double cab. The zerks are not labeled in the picture. Previous years were.
But as TS members have pointed out , there are zerk fittings on the 4wd's only, as like previous years.
2WD=no
4WD=yes
:ts:
Unless I am blind man..I was under there spinning the driveshaft and didnt see anything....
OOPS I read it wrong...yes I am blind then...hahahahahahaha
Changed the oil at 2700 miles. Will change it again around 5000 and every 3000 thereafter. Been following that procedure for my other cars and had no engine problems.
Thanks for the heads up on the forum :tu:
This is off subject but I know guys that work at/for TRD and they swear by Castrol GTX. They have told me that they have seen multiple failures using synthetic but never a failure using dino oil. I am using GTX in my cars and dirtbikes from now on. Can't beat the price!
Victor, I was under mine today wheeling around on a creeper putting on running boards. Just for kicks I checked my driveshaft and I did find grease fittings at all u-joints on both shafts. Mine was made 12/04, so I don't know if they stopped or started before the manual was made.
Retired Contributor
I personnaly have not been under a 4x4 yet to look. But i trust you :tu:
The pics in the manual dont show any. They show the shaft, the joints and everything has a descrpition, except the zerk fittings. The older models showed the zerk fittings in the pictures and they were labeled.
I am glad someone has the right info :tu:
So it is the same as previous years
2wd=no
4wd= yes
I stand corrected, :ts:
I'll post the pics I saw tomorrow.
Retired Contributor
Heres all the driveshaft pics for a 2005 Tacoma. They do not show zerk fittings
There are 2 pics also of the 2004 Tacoma 2wd -no zerks shown & 2004 4wd that shows the grease fittings.
Hey how many pumps of grease into the zerks. I've read 6 to 8 to until it seeps out of the u joint. Please help. Thanks
I owned my own service center for 15+ years and I've yet to hear one documented case where synthetic oil was the cause of a engine failure. This is simply not true...synthetic oil outperforms dino oil in every aspect. This has been documented time after time. Additionally, why do you think there are now some 'high performance' vehicles come installed with synthetic oil right from the factory?..seems to me these manufactures certainly understand the advantages of synthetic over dino.
1 - 20 of 21 Posts
