Hi all-
I recently purchased a 2002 Tundra 4wd. The transmission has a somewhat hard shift when downshifting from OD to 3rd in the highway. It’s not super hard but there is a noticeable bump felt in the vehicle. It does not occur when you manually press the OVERDRIVE OFF button or when the shift occurs at 40-45 mph. It only occurs at highway speeds and it does it every time at those speeds. So far I have done two drain and fills with Toyota atf. There has been no change. I am considering doing the auto rx thing next.
Any thoughts? I’ve read about the planetary gear but it sounds like that is a huge CLUNK. I am not having that major of a symptom. It has been happening for several thousand miles and since I bought the truck. Maybe a bad shifting solenoid or pressure switch?
thanks
Andy
thanks
Andy
