Does anyone have headrest monitors installed on the passenger seat with the fold-down table feature? (Btw, is this passenger seat feature only in recent Sequoias or is it in Tundras as well?)
Wiring for driver seat looks easy, but doing wiring on the passenger seat so that it still can be folded down to table position seems tricky at best...
If anyone has this done on their vehicle any description or even photos how the wiring tackles the joint that can bend 90 degrees would be great....
I just did this upgrade about 3 weeks ago...Very simple. Although I don't have any pictures it was easy pop off the table top, run the wires down the inside of the seat and leave slack inside of the seat (there should be extra length left over). If you ever have to drop the passenger seat down, the slack on the inside will slide out and still allow the clearance you need. Hope this helps.
i dont have that setup in mine obviously but just leave enough slack as stated above, and u will be fine.
