The heat shield on my 04 Tundra is rattling. It is located on the driver's side front by the cat. It is rusting away where it is mounted. Can I just eliminate it even though the gas lines are in close proximity? The gas lines are partially covered with an insulation where they are across from the heat shield. There is no heat shield on the passenger side and doesn't look like there ever was.
I had the same problem with my 2002 last year. Conveniently enough where it was
tack welded left a perfect hole to refasten it with some stainless steel nuts and bolts.
John
