Has anyone had any problems with the heater control. On mine the thing that change it from vents to floor to defrost is broken. If you take the dash apart you can see the knob is connected to a plastic shaft, the shaft is connected to a metal wire that open and closes the gates which directs air flow. That metal wire has broke out of the plastic, anyone have any ideal how to fix it?
I have the same problem with my heat control. I have to lay down and adjust the cable for the heat manually. I'm sure if you go to Toyota they will order that little plastic arm that connects to the cable. Can't be more then a couple dollars if that.
