Wanted to verify my hellwig sway bar is not upside down.
2003 Tundra lowered 2" in rear.
The center hump of the sway bar sites about 3/4" lower than the rear differential.
Also confused since have read the arms should be
153702
parallel with the ground. Others say the hump should be.
Moderator
The lengths look fine (i.e. the bar is positioned correctly), but I think the lower end links should be installed outboard of the bar ends. You have them on the inside.
Here is the Hellwig mounted on my '15 Tundra:
153713
