Looks like a lot of die cast aluminum to me. What a mess Jack.
Yeah, it's a mess, but it's still drivable. Isn't it amazing how Toyota or any other manufacturer won't stand behind repairing a defect such as a stress fracture unless you get into an accident where they're liable.
Dear jack mccarthy!
Tell us what your repair completed.
If it is possible with photos.
Regards George.
Moscow, Russia
P.S. Looks like I'm f**ked!
TOYOTA Sequoia/Tundra Club (
I haven't fixed mine yet only because I've been going through personal problems with workman's compensation and employment issues at the moment, but it's still driveable.
You can remove the top and bottom covers of the steering column by first turning the steering wheel left to expose the hidden screw under the wheel on the right, then turning the wheel right to expose the hidden screw underneath on the left. The third screw is accessible and below the steering wheel.
Spray down the steering column arm with PAM and slide the top portion off consisting of the rubber boot and top plastic cover. The bottom cover should come off very easily.
Remove the broken shifter with a T-30 torx screwdriver or socket wrench that will hold the T-30 bit to expose the shifting mechanism underneath. Once that's accomplished, the vehicle is at least driveable.
The bracket and base of the shifter arm along with the screws can be purchased for $110-$150 in parts. Most of the screws have threadlock on them and require a propane torch that you need to apply for 8-10 seconds to get the torx screws off.
You need to be careful with the airbag and disconnect the battery and wait a couple minutes for any residual charge to dissipate. I'll probably take some close up pictures of the parts between the tube and bracket that hold the whole tilt mechanism together. Once it's unscrewed, it can potentially spring apart.
I'm not sure what E-rating torx socket size is needed for disconnecting the bracket from the lower steering column, but I believe my father has it since he's done quite a few GMs and Ford steering columns.
Getting it done by the dealer is expensive, but I feel confident I could do the work with my father helping. Unfortunately, I just haven't gotten to it yet. Cheapest price from the dealership I was quoted was $500, but many have been quoting in the ballpark of $650.
EDIT: I just looked at your link to the russian forum. Seems like you already got the covers off. It'll probably be safer to unscrew the shifter arm baseplate off and use the mechanism the shifter arm ball slides into to control the shifting.
