1 - 14 of 14 Posts
I have a 2004 Double Cab with port installed keyless entry. The chirper has stopped chirping and I cannot find where it is located to replace it. Its not under the brake fluid res. Nor is it near the steering column. Any ideas?
Should be on top of the drivers side fender. Has a red cap or something on it from what I remember
The thingy that makes sound is on the fender, kind of dangling, right in front of the brake master cylinder. It looks like a foam cylinder shaped thingy with a red cap, just as described by Negrotundra. I wish mine would stop chirping, but if I disconnect all the noise making things it won't make noise when the alarm goes off.
You should be able to reprogram it so it doesn't chirp fer certain operations. ;)
Supportive Supporter
I filled mine with mud and snow a few months ago......stopped working all together for a while------------------:beach:
I think that only applies to 05+ models??? I know the reprogram deal didn't work for my 2003. So, I muffled mine with foam and duct tape :D
where can i find info on how to reprogram the chirp thing btw?:D
Mine ('05 DC) is between the plastic inner fender and the underside of the steel "engine compartment" on the driver's side. Mine apparently fills with water when I drive in the rain. A tech dug it out the first time.
Whenever I can get to it, I need to get back in there and fix it properly.
1 - 14 of 14 Posts
